Did you check for other symptoms or just stop when you found no spark? Check for fuel spraying from the fuel injector. If both fuel and spark are missing, suspect a defective Hall Effect Switch under the rotor in the distributor.
caradiodoc
Apr 27, 2009 at 6:40 PM
