1994 Dodge Spirit Sensor
1994 DODGE SPIRIT
177,000 MILES • 6 CYL • FWD • AUTOMATIC
JDOD
How do you replace transmission sensor.
Aug 2, 2010 at 5:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Raise the vehicle onto jack stands. If your vehicle sits very low to the ground, jack it up onto jack stands. Use the front jack point behind the radiator to raise the vehicle up. Place jacks stands underneath the front pinch welds and lower the vehicle onto the stands.
Climb under the vehicle and locate the speed sensor. The sensor is located on the bottom of the transmission, or it may be located on either side of the transmission housing. It looks like a small plug sticking out of the transmission with an electrical plug connected to its end.
Remove the electrical plug by squeezing the release tab on the top of the plug and pulling the connection apart.
Remove the sensor by turning it counterclockwise with an open-end or a crescent wrench.
Install the new speed sensor. Installation is the reverse of removal.
Aug 2, 2010 at 5:22 PM
