1994 Dodge Spirit loss of power
STAGEDAWG
Engine Performance problem
1994 Dodge Spirit 4 cyl Front Wheel Drive Automatic
runs rough when cold, and when pressing on gas sometimes loses power, let off and feather most times works.what can i do to fix this
Jun 19, 2010 at 10:57 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 19, 2010 at 10:59 PM
HELLLP ME
I have the same problem did you fix it i cant figure it out
Nov 19, 2010 at 6:58 PM
