1994 Dodge Spirit help
1994 DODGE SPIRIT
MAGICFREAK666
Shakes or Wobbles problem
1994 Dodge Spirit 4 cyl Front Wheel Drive Automatic
if the EGR Valve is pluged up will that make motor shake and not idle right and it spray's gas up throw the carb i'm thinking its either the egr valve or maybe the knock sensor it starts ever time but the motor will shake and wobble and stall out and wont idle right when you put it in gear it stalls out as well
Apr 2, 2009 at 3:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect EGR valve. If engine bogs down then EGR valve is OK. If engine smooths out then EGR valve needs replaced.
Thanks for using 2CarPros.com!
Apr 2, 2009 at 7:52 PM
