1994 Dodge Spirit hello please help
1994 DODGE SPIRIT
89,309 MILES • 4 CYL • 2WD • AUTOMATIC
CHEFF
Well all my other lights are working but my low beam headlights ......tail lights work , dash lights work, high beam lights work....changed the fuse still don't work an even changed the light bulb still didn't work help..please..
Dec 2, 2009 at 12:22 PM
CARADIODOC
  • 34,381 POSTS
The problem must be in the dimmer switch or the single wire that goes through the firewall to the low beam headlights.
If you don't feel the nice solid click from the dimmer switch, the switch is defective or out of adjustment. If the high beams turn off properly, it's probably working.
One likely place to look is for an overheated contact in the dimmer switch, or an overheated wire and terminal in the switch connector. Before you get too carried away with the diagnosis, did you try two new bulbs of the proper part number? If you only tried one, and it was a used one, it too could be burned out. The correct bulb is # 9004.
caradiodoc
Dec 8, 2009 at 6:04 PM
