1993 Dodge Spirit water pump
128,200 MILES • 6 CYL • FWD • AUTOMATIC
DAWN KENNEBECL
where is the water pump located
Mar 8, 2009 at 8:24 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:31233d89f6="Dawn kennebecl"]Engine Cooling problem
1993 Dodge Spirit 6 cyl Front Wheel Drive Automatic 128200 miles
where is the water pump located[/quote:31233d89f6]
Hi Dawn,
The water pump is located on the front of the engine behind the timing cover. It is run by the timing belt. And I would recommend replacing the Timing components along with the water pump, since the engine has to be torn down to replace the water pump. In other work it will be cheaper in the long run.
Mar 8, 2009 at 8:32 AM
