The car sat for about 2 years. I've put 3 cans of B12 fuel treament thru 3 yans of gas also changed gas filter, plugs. Once you start it up runs fine and idles fine could be 1/2 mile or 10 miles varies. Shut it off and start it up runs rough wanting to die floor it picks right up but if you ease it it bogs down, If you pull over and idle the idle at a higher rpm it will smooth out but has a very high idle. With your foot off the gas it will run 30-40 miles a hour not even touching the gas.
Jan 23, 2009 at 9:51 AM
