Car is well maintained, total engine rebuild at 189000
new parts included:
E.G.R.Valve
Map Sensor
I.A.C. Motor
Six New Injectors, Fuel Pump & Pressure regulator
Coolant temp. sensor
Dist Cap,Rotor, wires, plugs air and gas Filter
timing Belt & tensioner
Complete exhaust system including Catalyst
Defect: when cold engine statrs and idles fine, no
drivability problems at all cold or at operating temp
if I shut down the engine for 15 -30 minutes and try
to restart engine will crank for 10 - 15 seconds before starting, if I press on the accelerator 1/4 to
1/2 throttle crank time is shortend, hooked up a
pressure guage, feul pressure is 39 pounds steady
at Idle, when shutting off engine pressure slightly drops (37 lbs.),after 30 mins, pressure is at 33 lbs,
turned ignition on, pressure rose to 40 lbs. cranked
engine, still long crank before starting, only if I give
some throttle will it start normal.
Suggestions?
new parts included:
E.G.R.Valve
Map Sensor
I.A.C. Motor
Suggestions?
Jan 12, 2010 at 11:07 AM
