1993 Dodge Spirit heat
10,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN_WELLS
we had a mechanic install a new heater core and a new
thermostat we had heat before the parts were installed
he also put the antifreeze in but we no longer have heat
Dec 20, 2007 at 6:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:434c03626f="John_wells"]Heater problem
1993 Dodge Spirit 4 cyl Front Wheel Drive Automatic 100,00 miles
he also put the antifreeze in but we no longer have heat[/quote:434c03626f]
did you try to go back and ask the tech who did the work for you
I would after spending all that $$$$
i better have heat !!!
check heater control valve
and the vacuum line
Dec 30, 2007 at 2:00 PM
BLACKOP555
  • 10,386 POSTS
i belive you may have a air bubble lodged in the cooling system, it should be bled of air, take it back to your mechanic and have them bleed it.
Dec 30, 2007 at 2:03 PM
