1993 Dodge Spirit
1993 DODGE SPIRIT
17,000 MILES • 4 CYL • FWD • AUTOMATIC
PITA
WHEN YOU DO A DIANOSTIC CHECH HOW DO YOU READ THE CODES WHEN THERE FLASHING FROM THE CHECK ENGINE LIGHT
Mar 29, 2008 at 8:15 AM
BLACKOP555
  • 10,386 POSTS
the codes will flash out on the check engine light or a volt-ohm meter.
a code 12 will appear as one blink, then a short pause then two blinks then a longer pause, then the next code say 45 shows it will be four blinks and a short pause then five blinks and a longer pause then the next code will come.
Mar 29, 2008 at 12:47 PM
