1992 Dodge Spirit wipers
1992 DODGE SPIRIT
52,000 MILES • 6 CYL • FWD • AUTOMATIC
AHALLD
Wpers just stopped working. Checked fuses, ok, no noise when switch is turned on. Is there anything else to check and where besdes motor. Thanks for any help. Dave
Jul 2, 2008 at 12:20 AM
2CARPRO JACK
  • 11,533 POSTS
Use a test light to see if you have any power at teh motor when turned on, if nothing it could be the switch or the intermittent wiper control module. Check th eback of the switch (dark blue wire) for power then see if it has any power leaving it if so it but nothing at the motor the module is bad, if you have power at the motor and it doesnt work, the motor is most likely the problem
Jul 2, 2008 at 12:48 AM
