1992 Dodge Spirit timeing marks
DAKOTA146
Engine Mechanical problem
1992 Dodge Spirit 6 cyl Front Wheel Drive Automatic
100,000
Oct 8, 2009 at 8:11 AM
CH112063
  • 1,320 POSTS
Each camshaft sprocket has a mark(little pointer), as do their rear covers. The crankshaft sprocket has a small mark and the front cover(oil pump housing) has a mark also. With tension applied, all three should line up with their respective marks.
Good time to replace the water pump tensioner and spring. While apart. ok Joe
Oct 9, 2009 at 1:55 PM
CH112063
  • 1,320 POSTS
There is a service manual with this procedure for setting it up properly available on this website.
Oct 9, 2009 at 1:58 PM
