1992 Dodge Spirit fuel not gettin thru injectors
1992 DODGE SPIRIT
LOSER197401
1992 Dodge Spirit 6 cyl Front Wheel Drive Automatic
The car is starved of fuel, it will not run unless you feed it fuel thru the throttle body. have replaced fuel filter, map sensor, tps sensor, cleaned fuel lines, can hear fuel pump turning, gas is getting up to line leading thru injectors, it has spark. i think maybe fuel pump mayb is just too weak but am not sure about how to check that
Nov 6, 2008 at 1:48 AM
Check the fuel pressure make sure its withinn specs-if okay test for injection pulses at the injector/s with a noid lite
Nov 6, 2008 at 3:40 AM
