1992 Dodge Spirit Brake Lamp out
1992 DODGE SPIRIT
150,000 MILES • 6 CYL • FWD • AUTOMATIC
ERIC A
In warm or hot weather only. I keep getting a "BRAKE LAMP OUT" alert. I have tried replacing bulbs but nothing works. I've replaced the actual light socket with a brand new one but still the problem exists. There is electrical power to the tail light and it comes on fine. The bulb is a 2 filament bulb. The Large taller filament is the tail light, it works fine. The shorter filament is the brake lamp filament, and it is the one not receiving power. Once again, this is only during warm or hot weather temperatures. In Cold winter temperatures, both brake lights work fine. The left tail light assembly works fine all the time. Could this be in the brake pedal switch itself??
Thanks
Eric
Apr 25, 2010 at 7:38 AM
  • 110,244 POSTS
It's odd that it is affected by temp. Have you checked all the wiring? As far as the switch, it could be overheating, but I would think that would kill both lights.
Oct 1, 2010 at 2:29 AM
