1991 Dodge Spirit Fuel Filter
150,000 MILES • 6 CYL • FWD • AUTOMATIC
SKYREPAIR
How do i check the fuel pump fuse?
Nov 9, 2008 at 11:46 AM
  • 75,988 POSTS
You can easily tell if its blown the filament in it will break open.Also you can use a test lite on both side of the fuse if power is present on the fuse holder-the test light should lit if the fuse is good
Nov 9, 2008 at 8:58 PM
