I have a 91 spririt and it died out one day and i figured out it wasnt getting fuel so i tryed changing the fuel filter but that didnt help so then i decided to check the wireing to the fuel pump so i took all the rear seats out and found a nest from an animal cleaned it all up. theres 5 wires that run trough there that go to the pump/sending unit. they were chewed up so i replaced all the wiring and the car still wont start. I checked all the wries running through there 3 have ground 2 have power with key on. Ther pump doesn't make any noise when turned on. I was wondering if it has to be the pump thats bad? or if theres anything else i would be able to check first?
thanks
Dan
thanks
Dan
May 30, 2008 at 1:05 PM
