1991 Dodge Spirit
JASON WATTIER
1991 Dodge Spirit 6 cyl Front Wheel Drive Automatic
I Have replaced a coil because I have no spark,
I have changed the sbec(computer) because it told me CODE 44 No FJ2 voltage present at controler. Failure in the sbec.
Checked high voltage wire on coil to cap very little reisistance.
Checked dist. cap it's dry, rotor looks fine.
I recieve .333 volts at the coil and nothing on secondary end.
Jan 24, 2009 at 12:29 PM
BMRFIXIT
  • 19,053 POSTS
No spark ?
check and replace crank position sensor
check timing belt
Jan 24, 2009 at 11:43 PM
