1994 Dodge Shadow Wiper Arm Loose - Not moving
1994 DODGE SHADOW
MSTENSON
Electrical problem
1994 Dodge Shadow
The driver side wiper arm does not move when wipers are turned on. The arm can be moved manually. How do you tighten the wiper arm?
Jan 20, 2009 at 10:57 AM
  • 110,244 POSTS
IS the mount the are is mounted to moving? If not, there is a problem with the linkage. It is located under the cowl at the base of the windshield. Remove the cowl and see what has come apart.
Let me know what you find.
Mar 2, 2009 at 10:01 AM
