1994 Dodge Shadow will not start
BABROWN
Computer problem
1994 Dodge Shadow 4 cyl Front Wheel Drive Automatic
check engine lite was on ,was having starting problems . I replaced the plugs started and ran good,for a week or so, Now it will not start.
May 22, 2010 at 2:14 PM
  • 75,988 POSTS
Now it will not start. There's a problem in the engine management system you need to scan/pull the computer for code/s to find out what's causing the CEL to come on. Or you can do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
May 22, 2010 at 2:26 PM
