1994 Dodge Shadow Surges and missfires
72,000 MILES • 4 CYL • FWD • AUTOMATIC
TSCHPPT
When driving down the road the car intermitinly surges while holding the throttle stedy. It also surges badly if you let off the throttle to quickly. I've ohmed the TPS and have found no dead spots. I also have 5v at the TPS. I checked the spark plugs , wires , cap and rotor. There was carbon build up on all four plugs. I replaced the Injector and the fuel pressure reg. , brand new air filter, all my vacuum lines. I also checked for 5v at the MAP and its there, other then that Im not sure how to check it for proper operation. The Coolant temp sensor also seems to be working fine. Also my fuel comsumption has gone way up. The only code I get from the ECM is oxygen sensor signal input indicates a lean fuel\air ratio condition during engine operation. Can you help me find the problem?
Jun 8, 2008 at 1:55 PM
BMRFIXIT
  • 19,053 POSTS
[]Check the EGR
they do rust
lean issue vacuum leak
possible the EGR
Jun 12, 2008 at 11:38 AM
