1994 Dodge Shadow no spark
106,000 MILES • 4 CYL • FWD • MANUAL
94DODGESHADOW22
I have a 94 Shadow with the 2.2L engine. I drove it out to a job site and it just would not start up at the end of the day. I checked for spark at the plugs and at the coil, and I am not getting one. I just replaced my timing belt, and I checked to make sure it was still turning, and it is. I just replaced the battery, plugs, wires, dist, rotor, pickup assy, and the coil. The engine cranks, but I am not getting any spark. Any suggestions? I checked the codes, and it pulled a battery disconnect fault, but that is it.
Feb 19, 2008 at 5:02 AM
  • 75,988 POSTS
Try this check for battery voltage at the coil positive terminal while cranking engine over-if zero volts inspect and test the auto shut down relay ASD-
Battery voltage at the coil recheck the rotor and distributor cap-it has to go thru here to get to the plugs.
Feb 19, 2008 at 5:25 AM
