how to remove starter
WBUMGARNER
Two Wheel Drive Automatic I need to remove the starter on my 94 dodge shadow. What is the easiest or the best way to do so?
Nov 7, 2009 at 2:00 AM
  • 55,694 POSTS
You must start by disconnecting the battery and jacking the car up.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a guide to show you what you are in for when changing the starter. Yours will be a little different but will follow the same procedure.
Cheers, Ken
Jun 20, 2017 at 3:45 AM
