1994 Dodge Shadow - Emissions label missing.
1994 DODGE SHADOW
117,000 MILES • 4 CYL • 2WD • MANUAL
JWIRTZ
How can I find Vehicle Emissions Information if the label is gone? Need timing info.
Apr 22, 2009 at 6:49 PM
BMRFIXIT
  • 19,053 POSTS
4-CYLINDER IGNITION TIMING
2.2L & 2.5L
Place gear selector in Neutral or Park position. Turn off all lights and accessories. Connect inductive pick-up timing light to cylinder No. 1.
Start and warm engine to normal operating temperature. Disconnect engine coolant sensor lead wire. Radiator fan should come on, and malfunction indicator (CHECK ENGINE) light on instrument panel should illuminate.
Check timing through timing window in bellhousing. If timing is within 2 degrees of specification, DO NOT adjust ignition timing. If timing is not as specified, loosen distributor hold-down bolt, and turn distributor housing until specified timing is obtained.
Recheck timing after distributor hold-down bolt has been tightened. Reconnect coolant lead wire. Erase fault codes. Remove diagnostic equipment.
ApplicationDegrees BTDC @ RPM
2.2L 10-14 @ Idle
2.5L
Apr 23, 2009 at 8:17 PM
