1994 Dodge Shadow back up lights
122,000 MILES • 4 CYL • FWD • AUTOMATIC
SLICK0047
  • 6 POSTS
the backup light on the driver side is not working, i had the bulb replaced a new bulb socket isntalled the old one was rusted and still no light on the left side when i back up. The new bulb soket has 3 wires and the old system had 2 wires. What else can i check?
Aug 4, 2009 at 11:42 PM
JDL
  • 16,098 POSTS
Hello, with electronic transmission, it shows a two wire socket. Without electronic transmission, it shows a 3 wire socket. It may not make any difference, but the third wire, if violet with black tracer, Isolate it from ground. The violet wire with black tracer is voltage. Have helper turn the key on, put in reverse, see if there is any voltage. If you have voltage check ground.
Three wire connector, my info shows two violet with black tracer, one black. The black is ground, the other voltage, you only need one.
Aug 5, 2009 at 7:25 AM
