1994 Dodge Shadow adjustable cam gears
15,000 MILES • 6 CYL • FWD • MANUAL
CAPTJUANLOCO
Am building another 3.0 sohc engine for my car....having a problem finding any adjustable cams for it. Is there any cross-references? Mayhap custom manufactured? Money is not the issue within reason.
May 3, 2009 at 6:20 AM
2CARPRO JACK
  • 11,533 POSTS
Its a Mitsubishi engine, maybe you could search it out that way.Not too many people hot rodded those, they all went with theturbo 4 cylinders.If your must change your cam timing, see if you could possibly use cam bushings from another engine like aV-8 to move the dowel hole where you need it.
May 4, 2009 at 12:47 AM
CAPTJUANLOCO
Although i appreciate any fore thoughts into my problem. I am looking for a more specific , detailed answer....as what cam bushings / v8 could i use...any other cross reference applications ..etc. yes, that 3.0 sohc 12valve is the hardest to find performance anything for so any help would be appreciated. thanx again.
May 4, 2009 at 2:20 AM
2CARPRO JACK
  • 11,533 POSTS
to know what ones to use, you would have to mic the pins on your cams, then the pins on V-8 cams to see which ones are the closest, this would have to be done on theparts themselves, I dont know who would have that info.
May 4, 2009 at 7:59 AM
