1993 Dodge Shadow won't start no spark
CARL GENZ
Other Category problem
1993 Dodge Shadow Front Wheel Drive Automatic 85,000 miles
The car turns over fine but does not appear to have spark. I replaced the plugs, cap and rotor. I also had the coil checked. It is o.k. What else could be checked? Thank you, Carl
Dec 1, 2007 at 6:26 AM
  • 75,988 POSTS
For a start inspect and test the auto shutdown relay, ASD relay this one powers the coil/injectors/fuel pump. When you turn key to On -do you hear the fuel pump. also do this crank engine over and listen to the injector/s are they clicking? If not on both double check the ASD relay it has to go thru there to power all 3 of them. The computer energizes the ASD relay. See below
https://images.2carpros.com/forum/automotive_pictures/12900_asd_relay_2.jpg
Dec 8, 2007 at 10:33 PM
