1993 Dodge Shadow voltage regulator
127,000 MILES • 4 CYL • FWD • AUTOMATIC
PAPERMATE
Hello!. My 1993 Shadow still runs pretty good. My main concern is that I am still having problems with my car draining out of energy whenever it runs for a while. I have replaced the car with a new alternator, new battery, and new spark plugs. Still, I am going through the same problem. The car starts out fine running for a while but it is still showing the draining symptoms. If I turn on any headlights or heater, the car will run for a little time and it will drain faster. I believe it has something to do with a bad wire. Please help me!.
Thank You.
Jan 26, 2009 at 6:32 PM
DOCFIXIT
  • 18,828 POSTS
Check for a good ground on Black wire from batt to alt. If resistence is high will keep alt from charging.
Jan 27, 2009 at 2:51 AM
