1993 Dodge Shadow Throttle or Speedometer Sensor
157,000 MILES • 4 CYL • 2WD • AUTOMATIC
FAKIR
I have a 93 Dodge Shadow that was running in perfect conditions. All of a sudden it will take some time to shift into the next gears. It will up to 30-35 Mph then the gear will kick in instead of shifting at 25 or below. Now the car won't advanced either forward nor backwards. I've already changed the Transmission Filter and nothing happen. I've been reading and searching in the internet and found that it could be the Throttle or the Speedometer Sensor. Which on is it? or is the Transmission solenoid that I have to change. Please advise.
Oct 13, 2008 at 11:49 AM
  • 110,248 POSTS
Hi:
If the shifter linkage is placing the transmission in the correct gear, you should have it checked at a transmission shop. I feel sure that the TPS and speed sensor would cause the car not to move.
Nov 10, 2008 at 8:09 AM
