i have oil leaking from some where im going through 5 quarts a day ..i was wondering if it was a seal or gasket problem...or maybe cracked block
Jan 19, 2008 at 1:35 AM
✓Experienced Mechanic
Hi there,
wash the motor down and run, with that much oil loss you should be able to see the source of the leak, i would be looking at the oil pressure sender, and rear main oil seal or a faulty oil filter seal.
