1993 Dodge Shadow high idle
DAVE MAYTASH
Engine Performance problem
1993 Dodge Shadow 4 cyl Front Wheel Drive 130000 miles
car was idleing high i unpluged the thottle position sensor and idle went back to normal. does this mean the TPS is bad?
Sep 15, 2009 at 11:56 AM
GARNZY
  • 13 POSTS
i would say that to be the problem
Sep 15, 2009 at 12:03 PM
MATHIASO
  • 1,209 POSTS
The throttle plate may be stuck open,a binding cable or binding throttle shaft or black sticky/ gummy soot that may hinder the throttle plate to close and let the idle air controle valve do his job.
You may need to buy a throttle body cleaner.
remove it and find out what is going on inside.
Let me know if you need details for removing it.
Sep 16, 2009 at 10:27 AM
