1993 Dodge Shadow headlights
1993 DODGE SHADOW
180,000 MILES • 4 CYL • 4WD • MANUAL
ASPENDAD
Hi guys,I have a headlight out that is new. I can see the elements in the bulb and the are intact. The other headlight (drivers side) is good and working. I have inspected the wiring and as best that I can tell it is ok. My multimeter is at work so I can't test for voltage today but any Ideas?
Thanks, Aspendad
Sep 1, 2008 at 9:21 AM
  • 110,236 POSTS
Hi:
First I would make sure the bulb is good. You could use your multi meter to test for continuity. If the bulb checks good, make sure the socket is good and check if it's getting power. If it isn't, you'll need to work backwards until you locate the area where there is a power loss.
If you have any questions, let me know. And, I hope this helps.
Oct 18, 2008 at 4:50 PM
