1993 Dodge Shadow Fusible Link (Fuel Pump/Ignition Coil)
1993 DODGE SHADOW
140,000 MILES • 4 CYL • 2WD • MANUAL
DESANTIS621
Recently replaced the electric fuel pump (inside the gas tank), and the fusible link wich powers the pump and ignition coil. The fusible link has failed (as it should) 4 times in the past 3 weeks. Now it fails within the day! I am not sure how to troubleshoot? What can cause this fusible link to... well do it's job so well!
May 24, 2008 at 3:55 AM
BMRFIXIT
  • 19,053 POSTS
And you had no such an issue before the fuel pump replacement
then I will recheck the work done at and around the fuel pump
check the connectors and wiring
May 24, 2008 at 7:48 AM
DESANTIS621
When I replaced the fuel pump, the fusible link was also gone. I replaced both. BUT the link was 1 gage larger as I could not find one exact. I have now replaced the link withthe proper one, and it burns out quickly! I am thinking the relays are bad?
May 24, 2008 at 1:29 PM
BMRFIXIT
  • 19,053 POSTS
I would also check for a short in the circuit Is it the white 22 GA it feed the ASD relay check the red/white wire
https://images.2carpros.com/forum/automotive_pictures/99387_shadow_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_shadow1_1.jpg
May 25, 2008 at 1:45 PM
