1993 Dodge Shadow fuel system
150,000 MILES • 4 CYL • FWD • AUTOMATIC
MRYAN6
My shadow will start and run fine for a few minutes(10-15) then suddenly die and will not start again until left for a few hours. Fuel is not comeing through the injector when this happens. Where is the fuel pump relay so I could test that? and do you have any other ideas?
Feb 17, 2008 at 2:11 AM
  • 75,988 POSTS
When you turn key to On-do you hear the fuel pump? if not check for power at the dark green and white wire at the fuel pump connector-not there test both the fuel pump relay/auto shutdown relay located at left fender shield.
Feb 19, 2008 at 5:34 AM
