1993 Dodge Shadow compressor cycles on and off.
90,000 MILES • 4 CYL • FWD • AUTOMATIC
NWTF5
the a/c worked fine last year. using it for the 1st time this year the comp. cycles on and off about every 5 seconds.when its does run you can feel cold air and then warmer when it cycles off.
Jun 18, 2008 at 3:45 AM
DOCFIXIT
  • 18,828 POSTS
What you have discribed is a classic case of low refrigerant. An AC system check to determine if there is a leak needs to be done then if none charge it up.
Stay cool
Let me know
Jun 18, 2008 at 4:30 AM
