1993 Dodge Shadow brake light switch
1993 DODGE SHADOW
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
COMPUCOYLE
how do i put in a brake light switch? i can't get the old one out. when i turned the wheel and tapped the brake, a little shower of brake light parts rained on my foot.
Jun 30, 2009 at 2:35 PM
BUDDYCRAIGG
  • CAR REPAIR CONTRIBUTOR
  • 2,262 POSTS
it's pretty straight forward after you get the new part, you should be able to figure it out.
the threaded part of the switch goes through a hole and is adjustable.
you want it to rest against the arm of the brake pedal.
and when you push down on the pedal, the little spring loaded plunger comes out and the lights come on.
Jun 30, 2009 at 6:33 PM
