1992 Dodge Shadow Resistance and Ohms Law
SUNSHINE 03
1992 Dodge Shadow
Hi Everyone
I was once told that a common training tool for exposing electricians to resistance; was a large bulb in series with a small bulb. I believe it was on a 12 volt system and the bottom line is; that no matter what - the small bulb was the only one that worked. And another example would be; 6 light bulbs (2 ohms apiece) in series on a 12 volt circuit - resulting in none of the bulbs illuminating properly. Is anyone aware of these exercises and the resistances used in proportion to volts and amps ?
I really appreciate your time and any ideas.
Thanks
Aug 20, 2009 at 3:04 PM
  • 75,988 POSTS
Hmmmm.... Ohms law Its E over IXR The more resistance in a circuit the less power and vice versus E _______ I X R Ohm's Law defines the relationships between (P) power, (E) voltage, (I) current, and (R) resistance. One ohm is the resistance value through which one volt will maintain a current of one ampere. ( I ) Current is what flows on a wire or conductor like water flowing down a river. Current flows from negative to positive on the surface of a conductor. Current is measured in (A) amperes or amps. ( E ) Voltage is the difference in electrical potential between two points in a circuit. It's the push or pressure behind current flow through a circuit, and is measured in (V) volts. ( R ) Resistance determines how much current will flow through a component. Resistors are used to control voltage and current levels. A very high resistance allows a small amount of current to flow. A very low resistance allows a large amount of current to flow. Resistance is measured in ohms. ( P ) Power is the amount of current times the voltage level at a given point measured in wattage or watts.
https://images.2carpros.com/forum/automotive_pictures/12900_images_1.jpg
Aug 20, 2009 at 4:15 PM
CARADIODOC
  • 34,414 POSTS
E = I x R
Sep 6, 2009 at 8:54 PM
