1992 Dodge Shadow No spark
137,000 MILES • 4 CYL • FWD • AUTOMATIC
TJDUDE
My sons 1992 shadow wont start.No power to coil. I changed the ignition switch and the distributer pickup still no voltage to coil.The timing belt is ok still in time.The coil has 1ohm of restance.No one shows a ballist restor for this car what else should I check?
Thank you for any help.
Feb 15, 2009 at 12:54 AM
  • 110,246 POSTS
Hi:
This year car doesn't have a ballist resister. The computer takes care of it. Many times the wiring to the computer becomes corroded or loose. Shake the harness to the computer to see if that changes anything.
Mar 2, 2009 at 9:30 AM
