1992 Dodge Shadow No Power To Fuel Tank
1992 DODGE SHADOW
150,000 MILES • 4 CYL • FWD • AUTOMATIC
CANADA2
I have Spark at the ignition Fuses ok ASD relay seems ok But have no power to the fuel tank
Dec 6, 2008 at 5:25 AM
DOCFIXIT
  • 18,828 POSTS
Left front strut tower check fuel pump relay. First one left to right
Dec 6, 2008 at 6:50 AM
CANADA2
There is no Fuel Pump Relay. the only ones on the Left Front Strut are the Fan Relay A/C Cluch Cutout Relay and the Auto Shutdown (ASD) Relay I have Changed the Auto Shutdown (ASD) Realy there is power there When I put a test light on the ASD relay on the blue wire I was having a Clicking sound from one of the Relays and the car had started at that time now I hear no clicking sound with the test light?
Dec 7, 2008 at 4:07 AM
DOCFIXIT
  • 18,828 POSTS
Your looking on fender look to left at shock tower first one left to right Fuel relay, start relay and ABS
Dec 7, 2008 at 5:50 AM
CANADA2
Sorry there is no Fuel Realy on this Car on the Strut Housing there is only Anti-Lock Relay and the Starter Relay. On the left Fender is the Fan Relay, A/C Cutout Relay, And the Auto Shutdown Relay (ASD) Unless its somewhere else I have no idea? Now I do have Spark and I have Also have run Direct 12Volt Wire to the Fuel Pump and still no Change, I must Point out a few things First, the Timing Belt went so I Replaced it, The New Timming Belt is Set Properly, Secondly I'm Getting an Error Code 12 Problem with the stand-by memory circuit. Direct battery input to controller disconnected within the last 50 ignition key-ons? The last code it gives me is Code 55 Completion of fault Code Display on check Engine lamp. This is an "End of Message" Code? Any other Ideas would be Very Much Appreated Thank You For your help and Time
Dec 11, 2008 at 10:36 AM
DOCFIXIT
  • 18,828 POSTS
Check production date your car is wired like a 91. If you can get to tank connector check Dark green/Black should have 12v also check black wire for ground. Pump is powered by fuse #2-20amp
Dec 12, 2008 at 7:46 AM
CANADA2
[quote:3d5d9ef471="Docfixit"]Check production date your car is wired like a 91. If you can get to tank connector check Dark green/Black should have 12v also check black wire for ground. Pump is powered by fuse #2-20amp[/quote:3d5d9ef471] I Have Run a 12Volt Wire Directly to the Fuel Pump and connected it to the #2 Terminal on the Fuse Box. I have Started it by pouring gas down the Throttle body but its not kicking in the Fuel pump is it possible the Fuel Pump Stopped Working?
Dec 12, 2008 at 8:10 AM
DOCFIXIT
  • 18,828 POSTS
Either pump or wiring
Dec 12, 2008 at 8:16 AM
