1992 Dodge Shadow does not get primary voltage to coil
1992 DODGE SHADOW
190,000 MILES • 4 CYL • FWD • AUTOMATIC
JIMMEE
will not start for some reason i do not get primary
voltage to coil to make it fire that feeds the distribitor
and spark plugs the check engine light reads 32
edw1_2000@yahoo.com
Mar 29, 2008 at 9:46 AM
DTC 32 indicates an EGR system failure and /or EGR solenoid circuit Check for continuity on the black and gray wire between the coil and computer-if not open, the computer has a problem-it powers the coil
https://images.2carpros.com/forum/automotive_pictures/12900_coil_2.jpg
Mar 29, 2008 at 10:26 AM
JIMMEE
1992 dodge shadow doe not have EGR valve where
do i go from here
edw1_2000@yahoo.com
Mar 29, 2008 at 12:08 PM
No power to the coil-check the wiring if okay -the computer is gone.
About the EGR it came up on the software having one-
Mar 30, 2008 at 9:56 AM
