1992 Dodge Shadow Car Idling High
146,000 MILES • 4 CYL • FWD • AUTOMATIC
PLBIEGERT
  • 5 POSTS
My 1992 dodge shadow has been idling high around 2200 rpms. I have taken it in to a mechanic already who just cleaned idle air control sensor. The mechanic also informed me that if it happens again to replace the IAC which I did when it started to idle high again. After replacing the IAC the rpms dropped but went back up after a few miles. I then replaced the Throttle Position Sensor and still the same results. What else could cause it to idle high?
Apr 29, 2010 at 9:30 AM
  • 75,988 POSTS
Could be a vacuum leak or its locked-up in the open loop mode and computer throwing fuel at it when not needed or injector leaking/fuel pressure regulator
Apr 29, 2010 at 11:09 PM
WILLPINSON
What would cause a lock-up in open loop mode? A sensor? Bad connection? Or bad computer?
Nov 9, 2016 at 11:11 PM
