1992 Dodge Shadow
CHAD SPEARS
Electrical problem
1992 Dodge Shadow 4 cyl Front Wheel Drive Automatic
we put in a new timing chain but we have a problem when you turn ignition switch on dash lights come on but the fuel pump dont and the starter wont crank with key we replaced the starter relay and fuel pump relay still no sucess
Jan 27, 2010 at 5:03 AM
CH112063
  • 1,320 POSTS
Chad, the ignition switch gets its power thru an orange fusible link, it may have burned. The key in the cranking position finds its ground thru the starter relay to the nuetral switch on the transaxle. I think you may have on open in that fuse link or a bad switch. The test light and testing and repair information is layed out nicely by the 2carpros menu.
Test fuses with a 12volt test light. You can buy one pretty cheap at the site store.Check for voltage on both sides of the fuse links near the battery, they supply the ignition switch with voltage. A wire is sent to the computer through the switch also for computer use. It energizes the fuel pump if it reads a cam signal(distributor).
Feb 7, 2010 at 6:10 AM
