1991 Dodge Shadow trouble code 27 help
115,000 MILES • 4 CYL • FWD • AUTOMATIC
BROKENDODGESHADOW
car runs great when it will run sometimes no fire or fuel unhook battery a rehook and have fire asd i think have code 27 dont know how to check had code 24 tps sensor bought new one ran fine but didnt clear code then check engine stayed on always finally wouldnt crank put old tps back on cleared the code 24 light now off car might crank or not loosing fire and fuel pump help many thanks
Mar 1, 2009 at 11:18 AM
  • 110,251 POSTS
Hi
The code (27) is related to the injection. It imeans the injector circuit isn't switching when it's told to (TBI). When this happens, I want you to try wiggeling the massive wiring harness from the computer to see if that changes anything. Chances are you have a bad connection.
As far as the light, you may need to have a scanner to do it. Most parts stores will do it for free.
Let me know what you find.
Mar 2, 2009 at 9:27 AM
