Electrical problem
1991 Dodge Shadow 4 cyl Front Wheel Drive Automatic
Engine has intermitent spark,I've replaced plugs,wires,distributor cap,rotor,pick up coil and ignition coil.it will not fire at all until you pull the coil wire and check for spark,it only arcs when the key is released but once you plug it back into the distributor cap, the car starts and runs, it will start 5 or 6 times and then no more and i must repeat the process. what can it be??......HELP!
May 29, 2008 at 1:11 PM
