1991 Dodge Shadow no power to fuel pump fuse
1991 DODGE SHADOW
112,000 MILES • 4 CYL • FWD • AUTOMATIC
MARK923
I ran over a major pothole the other day & my shadow died.The fuel pump isnt getting power.I checked at the fuse & no power there.Can anyone direct me from here?Ive noticed that the light under the hood isnt working also.
Jun 30, 2008 at 9:01 AM
Inspect and test the ASD relay
Jun 30, 2008 at 9:13 AM
MARK923
I put in new asrelay but still no power to fuse- now what??
Jun 30, 2008 at 10:07 AM
The fuse is it the no.2 fuse?
Do this check for power on the coil's positive dark green and black wire and also at the injector harness-do you have it-
Jun 30, 2008 at 11:38 AM
MARK923
The car will run if I squirt starting fluid in the TB.Im assuming the coil is ok.I just dont have any power at the fuel pump fuse so no power going to the pump.I have replaced the auto shutoff relay-I dont know where to go from here!?!
Jul 1, 2008 at 12:43 AM
Did you physically disonnected the fuel pump connector and checked for power
Listen to the injectors while helper cranks engine over-do you hear it clicking-meaning its pulsing injector/s opening and closing. If not it might not be getting an ignition reference signal, the computer has to know the engine is turning before it will give gas-
Jul 1, 2008 at 6:07 AM
MARK923
thanks for the help- still cant get her to run-guess its time for a pro
Jul 4, 2008 at 12:25 AM
JUSTDON
  • 161 POSTS
They are pro's here.......
Imagine trying to diagnose a problem without being at the car...
Jul 9, 2008 at 12:58 AM
