1990 Dodge Shadow Leaking Oil
100,000 MILES • 4 CYL • FWD • AUTOMATIC
EARL64
The car is using oil about 1 quart a week. The oil is leaking somewhere on the back of the engine. It appears to be below the valve cover.
Jan 27, 2009 at 3:03 AM
  • 110,251 POSTS
Hi:
On the rear of the engine there are 3 places that can leak, the valve cover gasket, the head, the oil pan. I suggest getting engine cleaner (follow the directions) and cleaning the old oil from the rear of the engine. Once you do that, drive it for a day and check to see if you can locate the leak.
Let me know what you find.
Mar 2, 2009 at 9:45 AM
