1989 Dodge Shadow car won't stop running when you turn off
BNONNY3
  • 1989 DODGE SHADOW
Engine Performance problem
1989 Dodge Shadow 4 cyl Front Wheel Drive Automatic
I am having a problem with my car. When you turn off the key the motor keeps running. HELP I don't know what to do.
Wednesday, December 2nd, 2009 AT 4:34 PM
CARADIODOC
  • 33,916 POSTS
Sounds like the ignition switch is out of adjustment. It's on the right side of the steering column. Loosen two 5/16" screws to loosen the switch and slide it up or down to adjust it.
Caradiodoc
Wednesday, December 9th, 2009 AT 12:53 AM
DSHADOWALEX
This happens to me too occasionally, Adjusting the screws sounds ALOT better than replacing the ignition switch and Lock cylinder. I'll try it. (1994 shadow base)
Sunday, June 20th, 2010 AT 10:54 AM
