will not stay running and no gauges in dash are working
150,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
FLYNN-T
  • 35 POSTS
engine is cold it will start up and run three seconds and shut off and no gauges are working in my dash. there is a key lighted up with a circle around it and a line down through it in the right hand corner. I thought it was security so I took off negative battery cable to reset computer and did the lock unlock thing with the key in driver's door where that is the only door with a key hole, but still the same thing. could it be that my chip in my key is bad or what do you think my problem could be? thank you. starts up runs three seconds and shuts down every time even when engine is cold.
Apr 29, 2017 at 7:23 AM
  • 55,676 POSTS
It sounds like you have an alarm module that has gone bad. You might need to take it to the dealer so they can plug their machine up to see why the security is not working.
Cheers, Ken
May 1, 2017 at 1:07 PM
FLYNN-T
  • 35 POSTS
it is strange it did that all day Saturday and I went out sunday morning it started right up and ran til I shut it off and then it started to do the same thing-start up and shut off after three seconds-so it wouldn't be security would it if it started and stays running til I shut it off do you think it could be the key or something else-I can take the key out of the ignition in any position but they told me that wouldn't matter
May 1, 2017 at 10:58 PM
  • 55,676 POSTS
It could be a fuel pump causing the stalling, here is guide to check it when it stalls.
Cheers, Ken
May 2, 2017 at 2:45 AM
FLYNN-T
  • 35 POSTS
when I first get in to start my jeep and turn key on no gauges work at all and there is a light on in the right hand corner with a key in it with a line through it that wouldn't have anything to do with fuel would it-thanks for the help I appreciate it just trying to get this thing figured out
May 2, 2017 at 2:57 AM
FLYNN-T
  • 35 POSTS
when I started it on Saturday morning it ran til I shut it off and all gauges were working when it was running Saturday now gauges do not work and it will only run three seconds and shut off everytime
May 2, 2017 at 3:55 AM
FLYNN-T
  • 35 POSTS
starts up every time I try it but will only run three seconds and stops
May 2, 2017 at 5:28 AM
FLYNN-T
  • 35 POSTS
Just trying to give you as much information that I can-there is no check engine light that comes on so I can get anything on my hand held computer when I hook it up
May 2, 2017 at 8:23 AM
  • 55,676 POSTS
Yep get the scanner to get any codes. This will help us get the problem fixed.
Best, Ken
May 3, 2017 at 4:21 AM
