1988 dodge shadow, rotor not turning
TRAVLER02
[b:168414a48c]I have a 1988 dodge shadow. While driving it just quit. I had no spark so I check the distributor, the rotor will not spin when cranking. I check gear on end of distributor its ok, what could be wrong?[/b:168414a48c]
Dec 19, 2006 at 8:56 AM
BACKYARDMECHANIC
  • 337 POSTS
Does you car have a timing belt or chain . Motors that have belts use the belt to drive the distributor,along with the water pump,and cam shaft, causing it to turn. I suspected the timing belt (if equipped with one) has broken and this is the reason way the rotor does not spin. Good luck Backyardmechanic :(
Dec 19, 2006 at 9:11 AM
