1997 Dodge Ramcharger heat n a/c
150,000 MILES • V8 • 4WD • AUTOMATIC
HARLEYPLG1
heat n a/c doesn't come out of the dash vents is it a vacum hose or the switchs are bad or something other then that
Dec 6, 2008 at 5:53 AM
  • 110,246 POSTS
Hi:
It could be one or the other. The best thing to do is start at the engine and work your way through the firewall. Check all vacuum lines. There will be a hissing noise if you find the leak. If all lines are good, then move to the switch.
Mar 12, 2009 at 11:09 AM
