1990 Dodge Ramcharger wont turn over
200,000 MILES • V8 • 4WD • AUTOMATIC
SISSYLALA
My truck just died. I sounded like it wanted to turn over, but didn't. We thought it was a fuel filter. We changed that, it sounded the same but still no go. We changed the fuel relay switch, and got the same results. I sprayed brake fluid in the carburetor it sounded the same as before except the truck backfired a few times. could it still be the fuel pump which i believe is located in the gas tank, or should we be looking in another direction? Please help!!
Aug 20, 2009 at 9:54 AM
  • 110,248 POSTS
Have you checked for spark and fuel to the engine? Here are the how to's for that. Check it and let me know what is missing.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Jan 25, 2010 at 1:01 PM
